Hi I'm building a scooter and putting a V8 in a Suzuki van I need a mig n Tig welder what is the best price for punch please
I need mig n Tig in one plus I need blow torch oxy acetylene what is best please
Hi @shanefinnigan41,
This Bossweld MST185 Plus 180A MIG Stick and TIG Inverter Welder is a great option that includes both a MIG and TIG torch.
This Full Boar Multi 180 Inverter Welder can also be used for both MIG and TIG but the TIG Torch will have to be ordered separately.
For your oxy-acetylene torch, this Bossweld Adjustable Map Pro-Torch contains everything you need for general-purpose heating, brazing and cutting applications.
Allow me to tag @Noyade who loves his welding to see if he has any thoughts.
Welcome to Bunnings Workshop, it's great to have you here.
As a welder of many years experience, are you sure of what you're doing?
Which welding process are you looking to do first and foremost?
There are significant differences between MIG and TIG welding processes and even Oxy-Acetylene welding.
I can suggest the best welding machine for your application if you could please give us more information and
the amount of experience you have with these welding processes.
Welding is not just plug and play and you just "weld", as the case may be.
Vehicle welding is always fraught with fire risks around fuel and brake lines, you name it.
Unless you're going to use Flux-cored wire for MIG welding you will need shielding gas, this is the same for TIG welding, which is normally Argon.
I'm more than willing to answer any questions you have, bring it on.
Cheers,
Mike T.
I just wanted to add to the great advice already given by @MikeTNZ. Welding, especially when working with vehicles, can be quite tricky and comes with additional safety concerns, particularly around things like fuel lines, petrol tanks, and vehicle interiors. These are areas where a small mistake can lead to serious risks, including fires and explosions.
Before you start, I'd really recommend seeking out a mentor or experienced welder who can guide you through your projects, especially when you're starting out. Welding isn't just about having the right equipment — it’s about knowing the processes, understanding safety protocols, and learning to deal with the specific risks associated with your project.
I'm sure you'll find some great local welding courses and community groups where you can get hands-on experience with guidance. Working alongside someone experienced will help you develop your skills safely, and they can also offer tips on the best practices for welding in high-risk environments, like around fuel systems.
