What is the best premix concrete to use for steel carport kit posts that gives the best strength?
Hello @Dazzamtb
Thanks for sharing your question about what best premix is best for steel posts.
For setting steel posts in a carport, a high-strength premixed concrete designed specifically for posts is ideal. At the store, Easy Mix Post Mix offers good support for structural posts, as it’s formulated for rapid setting and doesn’t require additional mixing. Alternatively, Dingo Hi-Strength Concrete Mix or Easy Mix 20kg Supremo-32 High-Strength Concrete Mix are solid choices if you need extra durability and strength, especially in load bearing applications. Both options come in convenient 20 kg bags, perfect for one-time projects like carport installations.
I suggest looking at these products at the store:
These concrete mixes provide reliable support and are easy to work with, particularly for outdoor structures like carports.
