Started out as a small food stain, the more i cleaned the worse it got. Have tried bi carb soda, metho, bleach. Nothing works, it just keeps spreading. How do I make it white again?
Did you try jif? I have had good results with it on most stains
Hi @skyesheppard,
You've tried some pretty strong chemicals without any luck which makes me suspect the "stain" is not really a stain, it's actually the top layer of white pigment being removed to reveal a yellowed layer beneath.
Bleach removes colour by oxidizing the pigment molecules that give materials their colour. This process breaks down the pigment’s molecular structure, rendering the material colourless or lighter. Unfortunately, this is not reversible as the pigment has essentially been destroyed.
To fix the problem, you will have to either paint the benchtop or replace it.
The Dulux Renovations Range of paints, which can be used to paint the countertop back to white is likely a good option.
Check out How To Paint A Kitchen Benchtop With Dulux for some guidance.
Alternatively, you can check out our range of benchtops as potential replacements.
