Laying Pavers
I am developing a detailed plan for a garden in the restricted rear outdoor space at my daughter’s townhouse. She wants a small paved area (about 1.8 m square) so she and friends can sit outside. She wants charcoal porcelain pavers to match those in her balcony and entrance way. Not yet sure of the size say 400mm square by 20mm thick.
I have viewed the Bunnings DIY Advice re how to prepare for and lay pavers. I have also looked at a number of Bunnings Workshop Projects featuring pavers. Most of these have varied in one or more details from each other and from the Bunnings DIY Advice.
I have decided to use the Bunnings DIY Advice as the basis of my planning. However I have a few questions:
1 Base
In the Bunnings DIY Advice video a crushed rock base 100 to 150mm is recommended. To minimize cost and the amount of excavation, and given the small area with minimum foot traffic, can I with minimal risk reduce the base to maybe 50mm?
And could I get away with manual compaction rather than hiring a plate compactor?
2 Paver “underlay”
One of the projects I viewed used Strol geotextile over the top of the base. This is said on the Bunning’s site “to separate gravel or sand from intermixing with the clay layer.”
Is this recommended?
3 Edge support
The video shows a relative high and thick timber box frame on the two sides of the area to be paved which do not butt up to a wall. This frame seems to be a temporary and would be removed once the paving is completed.
However the video did not mention how the base stone is retained to prevent the stone flowing out and potentially undermining the pavers.
What is your recommendation?
4 Gap grouting
The video emphasises keeping a relatively wide 5mm clear gap between the pavers for grout. However the video did not provide detail on material, tools, and technique for applying the grout.
Is there a Bunning video or document which provides this detail?
