Hi all,
I have a 2018 Caroma Stylus dual flush toilet. The cistern has been leaking every since I moved in and I tried replacing the outlet valve seal with a bunch of Fix a Loo ones but none of them were the right size.
I recently bought silicone and cut it to the original seal size but it's still leaking after ensuring its the same size and its sitting flat and tight. Is there anywhere else I should looking to do a fix?
Not sure if I should cut the hole bigger in the middle of the seal to allow it a bit more room?
I've done a test to check it's not the inlet leaking as the leak still happens if the tank is full but the inlet water supply is off.
Really appreciate the help as the toilet constantly filling in the middle of the night is affecting my sleep
This is the original seal - it had bubbled when I took it out
