Hi everyone,
I like to install a Living Elements 1200 x 450 x 5mm Flat Edge Mirror.I did it once many years ago and it was easy as I remember. I needed a double sides tape and a glue.
Now when I read the instructions, it says that the mirror can be installed using double sided mirror mount tape and Selleys liquid nails and glass adhesive. Which are all okay.
Then in the 5. step in the instruction,when the mirror is mounted and pressed against the wall , it says to prop mirror for 48 hours to avoid movement.
How can prop a flat edge mirror?
Anyone know how to prop it or if it is really necessary?
Thanks,
Mariam
