The self closing gate on our pool fence is 42 years old and I have now fitted a new bespoke torsion spring spring as the original ine broke.. The problem I have is that when it closes it bounces open a couple of times before it closes securely. It is fitted with a 'D' latch which I understand to comply with council regs should not allow the gate to bounce open at all.
The 'D' latch is branded ARC, of sturdy construction and is secured by 2 bolts to a vertical gal pipe which forms part of the pool fence. I imagine that this is probably a common problem for which hopefully there is a solution. The mounting holes in the latch are elongated to allow for adjustment. The mounting section of the 'D' latch is curved so that it can be bolted to the vertical (pipe) fence post. I am wondering if the problem is adjustment or wear. Can you help me sort this out?
Chris Parker,
