I have some built in wardrobes that I’m wanting to overhaul. I’m not sure whether I should gut them entirely or just add flatpack inserts? It giving a makeover, what hinges would be recommended to use?
Hi @EllieBee,
Deciding whether to remove a built-in wardrobe or give it a makeover depends on your goals, budget, and the wardrobe's condition. Removing the wardrobe entirely is a good option if the structure is damaged, outdated, or limits the room's functionality. It allows you to start fresh and design the space to fit your needs, but it can be more costly and involve additional work, such as repairing the internal linings.
On the other hand, a makeover can be a more budget-friendly and less disruptive choice, especially if the wardrobe is still in good condition. Adding flat-pack inserts is an easy way to improve functionality, while updating the doors and hinges can modernise its appearance. If you choose to give it a makeover, consider whether you want the hinges to be a design feature or hidden for a sleek, modern look. Hidden hinges, like soft-close hinges, are ideal for a minimalist style, while exposed decorative hinges can suit vintage or rustic aesthetics. Your choice will depend on the overall style you want for the space.
If you are happy with the internal layout, a coat of paint would improve the look substantially. You could also make adjustments to better suit the available inserts.For the door, rebating the hinges so they are hidden would work well. Also, adding some trim work around the perimeter of the doors would look great.
Hope you found Mitch's reply helpful. Let me tag a few experienced renovators for their thoughts @EllieBee.
@Alyce_Pham, @raniia, @Nicolarose, @prettyliving, @Upcycler01 - what do you think?
Hi guys! Thanks for the suggestions. I’ve decided I want to demo the wardrobe as the dimensions are not compatible with functional insert, plus the wood is split in the framing.
Suggestions on how to proceed? I was thinking axe or sledge hammer lol
it’s just exposed brick behind
Hello @EllieBee
I suggest using a hammer in combination with a Craftright 380mm Wrecking Bar. The flat wrecking bar will allow you to get into the sides of the shelf and pry them off. Please note that these are destructive tools and will damage both the shelves and cabinet walls.
Please make sure to wear personal protection such as gloves, goggles and a mask when demolishing your wardrobe.
Hi Eric! I plan on gutting it entirely and installing a flatpack option into the space. The depth of it currently is just a tiny bit too small for any inserts. the wood is also split where the doors are hinged - I don’t think the previous owner drilled pilot holes before drilling the screws. I want to expose the brick and plaster the walls behind 🙂
Less care is required then, @EllieBee! Just be careful that no wires or water pipes are running behind the cabinetry.
I did it! I plan on installing flatpack wardrobes in the space. I’ll try to make them look built in by adding trims/framing 🙂
Should I plaster the wall and ceiling before doing that or is it okay to leave it exposed? On the other side of that wall is the bathroom (no fixtures on the wall behind). Thanks @MitchellMc for your ongoing advice on all my projects 😄
