Since beginning of November there are tiny insects coming inside the house through the floor level windows, French doors and entry door, into the living room. There is gravel and pavers outside, then a bit of a plant patch. They come once I open the windows, more so in the evening when it's cooler. They also appear when the windows are closed ?!? Although they are double glazed.
I searched and they are called snow fleas or springtails, they are not real fleas but they jump like them. They come in all sizes, the biggest get to about 4mm long.
Outdoor barrier Mortein spray did not work, also the type of outdoor solution that you spray via a hose from a container from Bunnings did not work. I found the information about using diatomaceous earth which I sifted in front of the windows on the gravel outside (I used to keep flower pots there, have moved them away since this started so that to expose the gravel to the sun and not provide any cover for any moisture).
This also did not work. Every day I manually crush them with tissues, then they come again... sometimes I use the vacuum cleaner.
Attaching a photo (zoom in for a better view) and 2 links with info I found.
https://www.whatsthatbug.com/springtails-all-you-need-to-know/
https://resultpestcontrol.com/what-are-springtails-and-why-are-they-in-my-home/
Would be grateful for any help on how to get rid of them.
Thank you,
Anca
