My Hot water tap is seized and the cold water tap leaks. Both have ceramic disks.
What do I do with the seized disk in the hot water tap?
And do I replace the ceramic spindle only in the cold water tap?
Hello @nothandy
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your tapware.
I suggest having a look at this guide - How to replace a tap washer. This will give you a general idea of how to repair your tapware. In step 4 you'll see how the spindle is removed. However, in your situation you'll need to replace the entire spindle with a Shaw & Mason Chrome 1/4 Turn Clockwise Ceramic Disc Basin Spindle or similar. Ceramic spindles can't be repaired as there are no spare parts for it.
