MacLaren cupboard is 1800mm height.Iam looking for a cupboard height max 1500mmCan you please share your suggestions for the same..Thanks
HI @sanjuks
You are looking for a custom height on you cabinet.
This can be done 3 ways
A . search plenty of furniture stores for a precise match or have it Custom Built to your spaces.
B.You can use modular furnature that stacks on each other as intended to reach the perfect height.
C Buy some existing KIT or furnature and if your crafty cut it down to the correct size as it suits you.
For example the following cupboard is actually 1600mm tall. But it is a kit and you maybe able to leave the kick board off or cut it off and drop its height to 1500mm.
I/N: 0597345
$226.95
Hi @sanjuks,
@Jewelleryrescue has provided some great advice here. However, if it needs to be under or exactly at 1500mm, I propose using two Kaboodle 900mm White Base Cabinet put on top of one another. This will approximately give you 1440mm if you add the foot base of the cabinetry it will give you another 40mm for a total of 1480mm.
The doors and hinges will need to be purchased separately, but you do have the advantage of choosing the finish of the door in the Kaboodle range.
Thank you..
Thanks Eric, that was really helpful
