I’m looking to improve the energy efficiency of our older home, as it gets uncomfortably warm in summer and cold in winter. I’m considering retrofitting Ametalin reflective roof insulation (or something similar) under the roof timbers to reduce heat transfer.
I’m based in Perth and have concerns about the potential for creating a high-humidity environment around the roof timbers, which I’ve read could lead to premature decay. Our roof doesn’t have soffits and is quite open, so I’m hoping this design allows any moisture to dissipate or drip out easily. Would this setup be effective, or is there a better alternative for achieving improved energy efficiency?
For context, we’re also planning to remove the old insulation, vacuum the ceiling, and install new insulation, which should help with temperature regulation too!
