how can you remove marks on white painted wall left from a kids sticky toy that was left overnight. The toy climbs the wall
Hi @dave011976,
To remove the marks, you can start by trying a simple solution of using warm, soapy water and a soft sponge. Gently rub the affected area in a circular motion to see if the marks come off. This method should work for most surface-level stains.
If the marks don’t come off with soapy water, you can try using an Eraser pad, which is highly effective at removing tougher stains. Be gentle with it, as the pad can sometimes be abrasive on paint, so it's best to test it in a small, inconspicuous area first.
If neither of these methods works, the marks might have penetrated the surface of the paint. In this case, you may need to do a touch-up with paint. If you know the wall paint colour or have a sample of it at least the size of 10cent piece then our Paint experts in-store can mix you up a sample pot.
