Hello, I'm in need of removing a split section of the pressure hose as I sliced it with my grinder. I'm having issues removing the fittting. Please any help would be great
Thank you
Hi @Craig2023
I think this is you Ozito 1800W manual To get your machine apart.
I cant see any replacement accesories online for ozito.
Take your damaged part into Bunnings they might be able to source spares more directly for you.
At $99 Buy a new machine and you will have a spare in case of break downs?
Hi @Craig2023,
To the best of my knowledge, repairing a split section of the pressure hose would be tricky, as you’d need a special hose joiner. However, I've never come across one. Using anything but a proprietary fitting would be a safety concern, and I would advise against it.
If you're able to provide the model number of the machine, I can check to see if a replacement hose is available.
