Hello all
Happy new year, 2025!
Iam planning to close this garden hose opening which Iam not using. Any thoughts on various ways to do it?
Thank you
All good. thank you, @MitchellMc
Awesome, thank you @Jewelleryrescue
Welcome to the Bunnings Workshop community @msgforsunil. It's terrific to have you join us, and many thanks for your question about covering a pipe.Great advice already from @Jewelleryrescue! A cap would be the easiest option and allow you to use the pipe at a later date if needed.Please let me know if you have any questions.Mitchell
HI @msgforsunil
Happy New Year too
Once the hose pulled out that looks like a 40mm to 50mm pvc pipe
So the neatest way is to just Buy a 40mm End cap in plumbing section and push it on un glued in case you change your mind later
There is a more square shaped cap if you like.
You should measure the outside diameter of the pipe just to confirm what size cap you need as all the sizes are avaliable.
Hope this helps
