Hi all,
My house has “boxed” aka concealed gutters and a lot of the fascia board are rotted around the corners, I imagine because water collects and leaks there.
The existing fascia boards are 35mm x 240mm. This is my first problem, I can’t find the exact size anymore. Closest thing from Bunnings is 30mm by 230. Would that be ok? I guess there will be a 5mm gap with the existing flashing.. is that fine?
In terms of fastening the fascia to the ends of the roof truss, what should I use? I have an impact driver but not nail gun, can I use screw instead of nail? Will that make it hard to take of in the future if necessary since all the screw heads will be bogged and hidden?
Last question, can I put some sort of plastic sheeting between the fascia and the gutter to prevent the corner from rotting out again?
thanks heaps!
