Hello All,
What is the equivalent of the below(Easy Leak Repair Sealant TURBO POLY SEAL 1 Gal + 50 ft fleece) in Bunnings?
Thank you
Hi @msgforsunil,
In order for our community to provide best advice, could you please let us know what you want to use the product for? It's best to provide as much information about your problem as possible so members can provide helpful and specific advice.
All the best,
Hello @msgforsunil
If you are trying to repair a leak in your roof the closest product that we have that's equivalent is the Fastfix Wet Shield 1kg One Coat Instant Waterproofing. The reinforcing fibres are already mixed into the product so there is no need for a separate fibre sheet. But if you can tell us more about your repair project, we might be able to recommend other products that will do the job.
Hello Jason
Sorry wasn't much clear before. Essentially, its Easy Leak Repair Sealant for metal roofs, flashing, rubber roofs, chimney caps, and concrete cracks. This Roof Leak Repair Sealant combines Urethane and Asphalt to give it the elasticity and adhering properties on metal, asphalt, cement, concrete, and other surfaces.
If you can provide more information on what you'll be using it for, we'll be able to suggest suitable products. I am unaware of any direct equivalents that are a urethane and asphalt mix. The Fastfix Wet Shield 1kg One Coat Instant Waterproofing that my colleague EricL has mentioned is likely the closest product with similar application uses that we have.Mitchell
sure sir. thank you @MitchellMc
