Hello members,
Need advice in managing drainage in the section of the backyard shown in the photos. The lot behind the fence is on the higher side (about 200mm at the higher side and around 100mm at the lower side) and the natural slope is from right to left. I have 600mm of gap between our concrete and the fence. I was initially planning to put up single sleeper retainers near to the concrete end. Then attach drainage mat on to the back of the sleeper and have 65mm socked agi pipe laid with gravel connected to stormwater system to manage water inflows from the lot behind. But that raises a question on how the water from our concrete path will be drained. Will the above plan work effectively for draining the water flowing out from our side?
Another idea I was thinking was to push the sleeper retainers further towards the fence and have the agi drain built in between the retainer and concrete. So that the water from the concrete and subsurface water from the lot behind will be drained.
I also intend to have plants in containers along the fence. What is the best way to tackle this?
Thanks in advance.
