We have very small laundry room and the door to it swings inwards which makes it very arkward. The door size is 2300mm x 720mm. I can't seem to find a bifold door or sliding door of that size.
Any ideas or suggestions?
Thanks
Hello @kelvinlee
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about getting a door for your laundry room.
It must be very difficult to work inside your laundry area when that door is open. One of the reasons you can't find the size you are after is because the common door height at that size is 2340mm. If you are after exactly 2300mm x 720mm you'll need to speak to the team at the special orders desk where they can quote you a custom height door. You can also get a quote for a bifold door at the same size. While you are there, please make sure to inform the team that you are planning on installing it as a sliding door, they will quote you an internal sliding door frame as well.
Thanks Eric. It might have been a measurement error on my part. At 2340mm, are you aware of a sliding or bifold solution that is off the shelf?
Hi @kelvinlee
The 2340x720 doors must be ordered in and are not available off the shelf. Plus, if it is to be used as a sliding or hanging door, it will need to be specified as such, because their construction is different. The same applies to bifold doors they must be ordered in, especially at the sizes you've mentioned.
