Hi Guys,
I'm looking at installing a window.
Does Bunnings sell the seal that attaches to the window reveals, it looks like it's around 150mm wide black matting.
Thanks,
Lee
Hi @Lee777,
Thank you for your question.
I am not 100% certain what you are referring to, but I believe there are two possibilities.
If you are weatherproofing around the window frame before installation of the window unit, you can use Window Flashing Tape.
If you are referring to the black rubber/plastic flap you sometimes see at the bottom of aluminium window frames, they are called a sill flap and they usually come with the frame. I believe they are made of a material similar to this CAgroup 150mm Plascourse.
Let me know if this doesn't answer your question. I'm happy to assist further if you can advise.
