Hi there
im looking to redo the ensuite in our old house and noticed the walls are out of plumb from top to bottom. I am still considering if to cut long wedges to attach to current studs to re-plumb the walls for tiling or to add in additional ‘plumb’ studs to plumb the ensuite wall - I can’t completely rip out and rebuild wall as it is part of a larger wall that backs onto bedroom.
2 questions I am thinking about
1. Which method above would you advise to plumb the walls in the ensuite to allow for tiling (there is more than one wall out of plumb that will also need to be done).
2. One of the walls that needs to be plumbed has an internal door separating ensuite from bedroom - how would I add door jambs and door to a wall that now may have a shim/wedge plumbing the studs or additional studs for plumbing?
hope this makes sense?
