I bought a click CLKTS03 digital timer from Bunnings - it has no instructions - I tried to download from the net with no luck - can you help?
Hello @Mccads
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about the Click CLKTS03.
Please allow us to get in contact with our supplier in regards to your query. As soon as we have more information, we'll get back to you.
Thank you for your patience.
Hi @Mccads,
Apologies for the delayed response.
I have managed to track down the operating manual and I have emailed it to you.
Please let me know if there is anything else I can assist with.
Why not provide the instructions directly here instead of creating unnecessary hassle for others?
There’s no secret to the instructions, right? This just wastes time, and now I have to repeat and ask again.
Welcome to the Bunnings Workshop community @ozbillwang.
I do apologise, but there is no direct download function for files on the Bunnings Workshop community. I've recommended to the supplier that they host the file somewhere, such as the product page on the Bunnings website, so we can provide a direct link to it for any future members. I have also notified our merchandise team, letting them know of the lack of instructions provided with the unit.I've emailed those instructions to you and apologise for the inconvenience.Please let me know if you have any questions.Mitchell
I got instructions in mine, it was just wedged between the timers and the card.
Have scanned and trying to upload here to help anyone who searches this laterpage 1-4page 5&6
Hello @Drewbear
Thank you so much for sharing the instructions to the CLKTS03. Let me tag @Mccads to make them aware of your post.
Hi, I have just purchased a Click digital timer. I have some garden lights set up on the timer. I have programmed the timer and it is all good. The device has 10 pre programable settings. I require to use only two. Winter settings and summer settings. I had thought you can program the times in click, and leave one on the Auto position function and the second program on the off position, allowing me to just change the auto switch between timers at the beginning of each the season. BUT. I can't find a way to switch the second setting to off while the first remains set to Auto. Does anyone know whether this can be done on the click auto timer? The instructions has no reference to it, so it might not be an available function.
Regards,
Loz
Hello @lozent
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your Click auto timer.
I understand exactly what you are trying to do with the Click CLKTS03 digital timer. Unfortunately, with that style of plug-in digital timer, the way the programming works is that all programmed events are stored together, and the “AUTO” function simply follows the entire list of ON and OFF events that are active. You cannot have one program bank running while another is stored but “disabled.” The unit doesn’t support separating or switching between different seasonal schedules with a simple toggle.
What this means in practice is that if you want to run your “winter” times, you’ll need to delete or clear your “summer” program entries, and vice-versa. Some people get around this by noting their summer and winter times in a notebook and re-entering them at the change of season, since reprogramming only takes a few minutes.
The “AUTO” switch position is only about whether the timer follows its schedule or not. If you move it to “ON” it forces the output on, “OFF” forces the output off, and “AUTO” means it follows all the programmed events that are currently stored. There isn’t a separate “bank” of settings you can toggle between.
As an alternative, I propose looking at the TP-Link Tapo P100 Mini Wi-Fi Smart Plug. It instantly turns connected devices on/off wherever you are through the Tapo app. Set a preset a schedule to automatically manage devices. Create a countdown timer lists for connected electronics. Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant. You can also create a custom schedule using the Tapo App for summer and winter. You can then simply switch over to the schedule that you want using the app.
Wondering if anyone could confirm if I can set this timer just to turn an appliance off at 5pm only. It will be manually turned on every morning but wanting to ensure it gets switched off at night hence the timer.
Hi @Mstacey,
Short answer, yes, you can set the timer to turn off the appliance at 5pm only and then manually turn it on in the morning.
You would first program it to turn off at 5pm, then hit the on/off button in the morning to switch it on, before then pressing the on/off button again to set it to auto. When switched from on to auto, it will remain on until 5pm at which time the programmed off command will kick in and turn off the power.
It sounds a bit wordy, but in practice it is not too difficult. In practicality, after programming the off command for 5pm, this would just mean pressing the on/off button twice of a morning to turn it on and then set it to auto.
The instructions can be found in the discussion above.
I bought a click CLKTS03 digital timer it has no instructions.
I have looked online with no success
Can you help with instructions?
Welcome to the Bunnings Workshop community @StRol. It's wonderful to have you join us and many thanks for your question on Click timer instructions. You'll find the instructions on this page. I hope that assists you. Also, I believe that the instructions might be inside the cardboard backing packaging. Last time I checked you needed to split the cardboard and they are held inside.
Hi Eric,
I also purchased a click digital display auto timer for a power point and can't seem to program it. It didn't come with any user manual and I can't find it when searching online, can you please email the user manual to my email I have registered to this workshop?
Thanks
Hello @mikethorpe101
Just a quick reminder that the instruction manual is sometimes very well hidden between the card and the timer as mentioned in another discussion. However, if you can't find the manual, I suggest looking at this discussion - How do program a Click CLKTS03 digital timer? by @Mccads. In the discussion one of our generous members @Drewbear posted the instructions in their post.
