Hello @Curiousnewbie
Welcome to the Bunnings Workshop community. It's sensational thar you join us, and thanks for sharing your question about attaching a door to your shed.
That is a bit of a challenge, technically a frame would have to be built inside your shed and anchored to the concrete floor in order to accommodate the door jamb of the door. I suppose you could just use angle brackets to attach the door frame to the shed, but the problem is that the shed walls were not designed to hold that much weight. It would probably rattle and damage the shed wall in the process.
Good morning @Curiousnewbie
My thoughts follow along @EricL's I would frame the rear side of the doorway and attach the timber to the concrete slab with right angled brackets. You could frame up the whole shed on the inside but would probarly loose a bunch of space. I would be concerned that the added weight of a door would tear the metel shed as is.
If you are trying to make it more secure then maybe some square metal tube bracing the door diagonally would also work.
Hi @Curiousnewbie
As both @EricL and @Dave-1 have mentioned, a wooden door may add too much weight for the lightweight frame. The best and most durable timber and also very cheap, would be to simply use treated pine fence palings fixed to 75mm x 16mm treated pine battens made up as the frame.
That aside, can I ask why you want to replace the metal door with a wooden one?
Nailbag
Well we don’t need the shed as a wood shed anymore, so I’d love to convert it into a cute little potting shed. I don’t know how tricky it would be to turn this beat up shed into anything pretty, but I’ll be putting raised garden beds next to it and would like to end up having a sitting area out the front. I don’t really know where to start! Any ideas welcome!
Morning @Curiousnewbie
That will be an interesting project.
With the raised beds I would give them a little space off your wall becuase of the concrete slab you have. Just to stop water seeping down the raised beds and tehn onto the slab.
Things to dress up your shed -
- The plastic styled lattice/privacy screens could help in vines ect growing up the side of the shed.
- A curved pathway to the shed itself.
- Maybe a fruit tree or two in the raised garden near the shed to grow and give shade.
- I did think of a window but then we are back to the structual intergrity of teh shed itself. So thats a no.
- Install a tap out near your shed for ease of watering.
- A small watertank?
Those are excellent suggestions from @Dave-1. I would also like to recommend removing the front section of your shed and building an open frame. This will allow you to put in a potting table and garden material but still have protection with the shed walls and roof. I would also propose adding a large water feature a succulent garden and shade cloth to provide a comfortable section to sit in away from the sun.
Actually there’s a water tank to the left! I love your idea of the lattice and vines. So to let some light in the shed, do you think I could make a wooden half-door? And get rid of the door that’s there? Or would that be a bad move?
Oh wow there’s a thought! Would that be a hard job taking the front off? I could somehow add a little pergola or awning to the front of it too! I’m not sure how to go about things, but I’ll have a look at the shed again tomorrow and see if the front panel could be taken off without damaging the rest of it. How do you propose I build an open frame? With wood? Pardon my ignorance! I’m wanting to paint the shed a different colour too.
Your shed is put together using screws and rivets. If you can track these parts down, you'll see exactly where you need to disassemble the shed. The frame is a simple rectangular box made from 90x45 framing timber, it will take the place of your door and front panel of the shed. It needs to be anchored to the concrete and the shed needs to be anchored to the frame. You can paint your shed any colour you like.
Thank you for your ideas! I shall look for a pic of something similar and give it a go.
