I have to clean the high outside windows at a rental prior to final inspection on moving out, would a pressure washer with window cleaner be suitable on low pressure? or would one of the clip on to hose window cleaners be a better option
How high are your windows @BloodHammer? Would a 3.66m extension pole be sufficient?
Hi @BloodHammer,
Likely, either of those options would work, provided they were able to reach your windows. As Jason mentioned, an extension pole, if long enough, would assist. You can pop on a squeegee head and check the windows that way.
