Welcome to the Bunnings Workshop community @sarah71. It's brilliant to have you join us, and many thanks for your question about connecting a hose.The hose fitting you've pictured is quite budget-friendly. If it's leaking when connected to the tap, then either it has failed, or the rubber O-ring on the tap adapter needs replacing. I'd recommend picking up a Nylex 12mm 3 Piece Plastic Hose Connector Set. It includes a new tap adaptor and click-on fitting for the end of your hose. There's also an additional one that you can use for your spray nozzle.Please let me know if you have any questions.Mitchell
Thank you I got an o ring and it’s fixed. Now I need to find which fitting will enable me to have more than one hose plugged into the tap like a double adapter
Hello @sarah71
I propose using the Pope 2 Way Brass Threaded Tap. It has individual cut off valves that will allow you to use the tap even if only one side of the splitter is being used.
