hi .
i first time project planning to a free standing composite decking on my backyard.( on grass ) , 10m x 2m.
please advice.thank you
Hello @Charliechau
Once you have drawn up your decking frame plans, I suggest sharing it with the community along with any questions you might have while designing the frame.
hi Eric,
thank you for the info.
Charlie
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about building a free-standing deck.
I suggest having a quick look at these guides - How to build a low-level deck by @Adam_W and How to build a deck by @MitchellMc. These guides will give you an idea of how to plan your decking frame which is the foundation of your deck. While you are drawing up your decking frame plan just keep in mind in which direction the decking panels will be facing. How far off the ground do you plan to have the low-level deck? This is critical as the more space you provide under your deck the better air circulation will be.
Here is a link for ideas and inspiration: Top 10 most popular deck projects
I also suggest having a look at the Bunnings deck building guide:
Before you begin your plans, I also recommend checking out the rules and regulations of your local council regarding low-level deck sizes. There might be size limits in place so it's best to double check before you start.
