The doors and trims in my house are currently painted with a mix of water and oil-based enamel that is probably around 15 years old. Is Dulux 1 Step Prep a suitable primer before painting over the oil-based sections with water-based enamel?
Also, it says that sanding is not required on most surfaces. If the existing enamel is gloss, should it be sanded first?
Thanks!
