I am designing a deck and verandah to go at the back of my house. The deck will be 9m wide x 4m deep. My backyard slopes, so the greatest height from the deck to the ground is 1.5m.
Deck bearers and joists will be MGP10 H3. Bearers 2x190x35, joists 190x45. Joist spacing 450mm for 19mm merbau decking boards.
The deck is to be cantilevered 600mm over the last row of posts/bearer.
My question is, can I attach the verandah posts to the perimeter frame of the deck (in-line with the handrail) if the deck is cantilevered? ie. the posts holding up the roof won't go all the way to ground. I have calculated that 3 posts for the verandah beam are required along the front of the deck.
Does adding a roof load to the deck change the maximum spans of the deck on its own? I couldn't find this information in any span tables I was able to find.
TIA.
