Hi Team!
I have a Mondella curve tap sink mixer brushed steel. I’m looking to replace the aerator in the tap as the flow is really slow. I have replaced it before through special orders for the entire aerator tip including the casing for over $60. Is there an aerator insert that I can buy to replace it the internal part of the casing? The size is unusual so it does not fit the standard tap aerator size of 22-24mm which the Mondella aerator is slightly smaller. It’s quite annoying as the tap works well and sturdy but the aerator is unique and I don’t want to spend $60 for another tap end with the aerator inside.
