I bought these pruners and used them today, but found after 15 mins they stopped due to thermal overload! It was a cool day of 20 degrees. They were warm in my hand but definitely not hot.
Took them back for a replacement, but the same behaviour happened after about 10-15 mins of cutting. Most of the branches I was cutting were less that 15mm.
After resting the tool for 10mins, I was able to get another 15 mins out of them, until they stopped.
The 4amp battery was showing 3 lights the whole time, ie full power.
None of the reviews show any hint of this issue. Is it a bad batch, or have you heard of this before? Do the Ryobi pruners do the same?
Thx
https://www.bunnings.com.au/ozito-pxc-18v-cordless-pruning-secateurs-skin-only_p0293760?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink&productName=applinks&pid=0293760
Hello @Oopsee
I'm sorry to hear that your Ozito pruner is overheating. One of the reasons your tool would overheat is the motor was put under a great deal of stress. According to the operator's manual on page 4 Pruning can be done all year round. It is advisable to prune lightly when the shrub/plant is in full bloom or in its peak. Prune more heavily when the plant is less active and dormant. Take note of the maximum cutting capacity, softwood: Ø25mm, hardwood: Ø15mm.
Cutting larger dry tougher pieces could cause the motor to thermally overload and prevent the cutter from operating properly. Since this is the second tool you've received that is overheating, I suggest returning the tool for an exchange and giving it one more try. This time however, I suggest cutting the branches starting from the thinnest section and working your way to the thicker ones.
Thx Eric.
Unfortunately the branches don't come in size categories, but in this case are bundles of all sorts of aggregates. The job won't allow me to pick and choose which branches come next. I wasn't cutting anything greater than 20mm. I used a small chainsaw for them.
*** Do all the pruner brands have a thermal cutout mechanism?
Hi @Oopsee,
I've spoken to Ozito, and this appears to be a case of the thermal cut-out being tripped. This can occur on any temperature day with continuous use or where you are consistently cutting at the maximum capacity. It should not occur with general pruning use around the garden. However, if you have a pile of max-capacity limbs and you are standing there cutting them up continuously, it will trip the cut-out at some stage.For continuous use, you might like to return the unit and consider something of a higher power like the Ryobi 18V ONE+ HP Brushless Pruning Secateurs with a slightly higher cutting capacity of 28mm for green material and 23mm for harder brown material. We also have the AEG 18V Fusion Secateurs with a cutting capacity of up to 30mm for softwood and 25mm for hardwood.Alternatively, you could consider the Ozito PXC 18V Cordless Pruning Saw or Ryobi 18V ONE+ 6” Pruning Saw.All pruner brands have a thermal cutout to prevent the motor from burning out. But, if you are using a unit with some headroom to its maximum capacity, it will be less likely to trip the cut-out.
Thx Mitchell. I'll look into the other models suggested. Thx for summarising their specs!
