Hi
I've just bought a home and it needs fixing but where do I start, it needs a kitchen, Main Ensuite, painting and flooring, i think that's all.
I just don't know where to start at
Thank you
Hope someone can lead me in the right direction
Hi @Ria22,
Renovating a home can feel overwhelming, but breaking it into steps and individual project areas makes it easier and less overwhelming.
If there are any structural issues, it is important that they are handled first. This step will likely require the assistance of a suitably licenced tradesperson.
The kitchen should be next as there is only one in your home. Start with any alterations to the plumbing and electrical, as these parts of the renovation will require the assistance of a professional.
Once the kitchen is back to being operational, move on to the ensuite. Assuming you have more than one bathroom in the home, you can take more time with this work.
Once the kitchen and ensuite are done, move on to the flooring. Install it after big renovations to avoid damage but before skirting boards if you’re using floating floors.
Painting should be the last step. This keeps your walls fresh and free from scuffs caused by other work.
Allow me to tag @Nailbag, @Dave-1 and @redbournreno for any guidance they can offer.
Let me know what you think.
Welcome to the Bunnings Workshop community @Ria22. We're pleased to have you join us and trust you'll get lots of helpful advice and project inspiration from our wonderful community members.
One of our resident Bunnings D.I.Y. experts Mitch recently wrote a guide that should be very helpful to you: How to budget for a home renovation. You can also check out these helpful guides: How to plan a kitchen renovation and How to plan a bathroom renovation.
The key is careful planning and breaking the tasks down into manageable projects so you don't get too overwhelmed.
Hope that helps,
Congratulations @Ria22 on your new place 🙂
Exciting times ahead! Trying to work out where to start and maxing out the thought process in doing it all at once is something we all do 🙂
I approach it a little differently to the way @JacobZ has mentioned 🙂
- Rooms that you need for the house to run.
- Kitchen, mine is old and has been old for the past decade. Slated to get done next.
- Bathrrom, functional but ceiling has water damage issues, no water leaks.
- Toilet, I have 2, one in the bathroom. One in the laundry.
- Bedrooms
- Loungeroom
- Garage
- Flooring
Outside
- Pool
- Sewage
- Stormwater
- Gutters
Life moves along and I found that as things happened and my focus would shift to repairing the issue/s and that would flow onto the other sections mentioned above. My sewage repair cascaded into stormwater repair and then gutter repair lol As one part was fixed others would show up.
I have reovated my loungeroom and one spare room, laundry. Also had those sections fo the timber floor sanded and varnished. The sanding and bringing up nicely meant that those rooms were renovated to finish off the areas. 🙂
Now that I want my kitchen to be started, I have just repaired my loungeroom floor as it steps into the diningroom and then the kitchen. Those two rooms are going to be redone together.
With your new place 🙂 Think of the rooms that can be afforded to be out of action for a period of time, add an extra 20% of the time as it will be longer especially if you have not done renovations before.
Kitchen can be shifted to elsewhere with a portable stove/hotplate. Microwave is your best friend.
Bathroom, that will take awhile and probarly be costly if you redo the lot. Bathing in the laundry is a potential swap but cold in winter.
Toilet, a porta potty may need to be hired.
As @JacobZ has mentioned, painting is last, tho that said I have painted my spare room and lounge but not the hall. I have some holes that need to be fixed first.
When you get a trade in to do whatever part of the work that needs to be done, ask them if they know anyone they recommend for the other parts, plumbing, sparky, carpenter, (if you are happy with the work the trade is doing 🙂 ) this way you will end up with a pool of trades for work that will show up for sure. Break down the house into doable sections like a jigsaw puzzle, then work away on that corner or wall first.
Hi @Ria22
I think the breakdown @JacobZ has provided us an excellent starting point for you.
As someone who has renovated several homes top to bottom, my No 1 piece of advice is to get the house in order before cosmetics. In other words, again as @JacobZ mentioned fix any structural issues, plumbing, electrical. Things that need trades for. But don’t spend money in areas you intend to rebuild unless there is a safety concern. That’s just wasting money. Yes there will be some short term spends that will need redoing to suit your lifestyle, just keep it to a minimum.
Don’t start too many projects that can drag out unless they are connected to each other. Like knocking a wall out if you not ready to work on what’s on the other side.
If this is your first Reno, start small and build your skills up annd enjoy the process. And don’t tackle anything you’re either not up for or requires a qualified tradesman. My moto is that I do as much as i can myself so i can afford to pay for things I don't want to do, cant do to my own high standards or shouldn’t. And always get compliance certificates from plumbers and sparkies. This proves they have done the work according to local regs with relevant industries.
And of course if in doubt come back to the worship as often as you like for help and ideas like in the links @Jason provided.
Nailbag
Thanks guys I really appreciate now where to start with the kitchen 😆
Now to find someone to help me as it's only a small kitchen probably 2mtr x 2 mtrs and I do want to move a small wall that's not load bearing, well that's what the building and pest guy told me... just have to move it out a bit for the fridge and pantry ..
For a small project like this a decent local handyman service can confirm if the wall is load bearing and handle the wall removal. An electrician will required if it has any cables and/or PowerPoint needing relocation
I Would then recommend getting out one of the Bunnings Kaboodle designers. For $100 they can work with you to design the most effective kitchen layout and quote on all the components. The $100 comes off the cost of materials should you place the order.
Again if your not up to it, the handyman can install the cabinets and possibly splash back etc. a qualified plumber and sparky will be required for those types of works.
Nailbag.
Hello @Ria22
Can you please post a photo of the kitchen and bathroom you're planning on renovating. I'll be more than happy to draw up a sample layout of your kitchen and bathroom if you can provide the measurements as well.
