Wondering best way to store (probably hang on a wall in garage) my Ozito cordless pole hedger I just purchased
Hello @IanTru
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about how to store your pole hedger.
I propose looking at the "U" hooks available at the store. Most of them are designed to hold garden tools and power tools. They can either be screwed in or come with a self-tapping screw attached to the body. It all depends on where you will be hanging it. I propose visiting your local store and having a look at the possibilities. If you have a specific question about a certain product, we will be more than happy to provide you with advice and information.
Hi @IanTru
As this is a tool I assume won't be used that often, I would consider storying higher horizontally on your wall and save valuable vertical space in your garage. I store my garden tools in a small shed up the sideway and my line trimmer is stored horizontally. There are a couple of options for hooks. Either two of these or I found this system which will allow you to hand and store both vertically and horizontally.
Nailbag
Thanks
Yes I’ve done that now. As I already had the “2 slot wall strips” for shelves, I’d hoped that that “system” might have had some sort of hook to latch onto those. It seems that it doesn’t.
Thanks Eric
As I already had several of the “2 slot wall strips” for shelves, I’d hoped that that “system” might have had some sort of hook to latch onto those. It seems that it doesn’t. So I got a couple of the hooks you suggest.
