I have these two doors that are different from the rest of the kitchen doors. Do you have any suggestions to make them look consistent with the rest of the kitchen? Note that the whole kitchen doors are laminated.
Welcome to the Bunnings Workshop community @sema. It's amazing to have you join us, and many thanks for your question about cabinet doors.It would be difficult to take the current doors and make them resemble the others. That would require significant and detailed routing work to the face to create the same profile, which is not easily achieved. You might be better off replacing them with something like the Kaboodle 450mm Gloss White Heritage Cabinet Door with similar inlay detail. Be sure to check the dimensions of your doors to see if they will match. The Kaboodle doors are 717mm x 447mm. Bear in mind that the design, though similar, is not quite the same.
From there, you could use the Dulux Renovation Range and paint the rest of the cabinetry white to match. That would give you a pretty consistent look. Here's a helpful guide: How to paint kitchen cabinets.Please let me know if you have any questions.Mitchell
