HI Memebers
looking for some product advise to fill these holes made for installing conduits.
Hi @antrix_bansal,
You can fill the chase with Gyprock CSR 4.5kg Less Mess Multi-Purpose Joint Compound.
Fill the chase to just below the surface of the wall and then allow it to dry.
You should then put Fibreglass Builders Joint Tape over the chase so that it overlaps the wall on each side, then apply another coat of joint compound to conceal it.
Once dry, sand it smooth then prime and paint.
Hey @JacobZ came across this post in a search as I am about to fill some chasing in my kitchen wall. Can you recommend a primer to use before painting? cheers
Hello @crisis
I suggest using Dulux 1Step Prep Primer, Sealer & Undercoat 4L. It works on most surfaces including brick, masonry, paper-faced plasterboard, timber, MDF, render, concrete, cement sheet, galvanised iron, Zincalume steel, PVC and previously painted surfaces.
