Hi there community,
I have a concrete services/path area (where my hot water system, pool pump, aircon unit etc are located). The fall of the concrete in some areas doesn’t allow the water to drain properly and as a result it pools in these areas. I would like to tile the area myself but inorder to do so, I need these levels corrected with the correct falls. What can I use to increase the height of some of these areas. Some areas require only a few mm but others are 15mm or so.
Thanks so much!
