Will 100mm unslotted corrugated pipe connect to a 100mm pitboss?
TIA
Hello @klast
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your drain coil.
In order to link your drain coil to the Everhard EasyDRAIN Pit Boss Connector I suggest using either the Vinidex 100 x 100mm PVC Draincoil Adaptor or the Vinidex 100 x 90mm PVC Stormwater Draincoil Adaptor. Please note that it might be necessary to install a bit of PVC pipping between the Pit Boss and the adapter. I propose test fitting the parts at the store just to be sure.
Please note that connecting your drain to your storm water pipe needs to be carried out by a licensed plumber for safety and compliance.
