Wonder, can order Ryobii tools spare parts at Bunnings? Need replacement whipper snipper spool?
Bunnings sells the tools, so should provide spare parts when needed.
Hi team, I have a RYOBI shredder RSH2445T and this broken parts. Guess it is called adjust plate ? Anyway it is the one which is against the blade. Wondering if it is still available for purchase or even manufactured ? Online search seems give me no luck.
Hi @chxzqw,
I've had a look at the exploded diagram of your RSH2445T shredder and have identified this as part 52. The specific part number is 099710001053.
I'd suggest getting in touch with our Spare Parts team as they will be able to assist you with ordering a replacement part.
Let me know if there is anything else I can assist with.
Hi Jacob,
Many thanks for the part number and the link. Have just submitted the online form through.
Hi @volkerku,
There are options for replacement spools such as this Ryobi Line Trimmer Spool And Line, Ryobi 2mm Whisper Series Trimmer Line or this Ryobi 18V / 36V Replacement Line Trimmer Spool And Cap, but we would need to confirm compatibility with your whipper snipper.
Can you advise what Ryobi whipper snipper model you own so I can help track down a suitable replacement for you?
There will be a plate somewhere on the tool showing the model number.
If a replacement is not held in store, our Spare Parts team could order one for you.
Alternatively, you may be able to just replace the trimmer line if the spool is still intact.
I'll happily assist further once you can provide a model number.
Please advise if you can secure a spare part for my Ryobi corded Circular Saw, purchased from Bunnings in 2012/13. Saws Model Nos. ECS23235. Serial Nos. 102200126. The Part I now need is a Soft-start Module. It’s a small electronic module that’s now faulty! I am a retired engineer & and OK to do repair if module is still available and price is right. Thanks Gerry Johnston (local store is Artarmon NSW)
Welcome to the Bunnings Workshop community @GerryJohnston. It's a pleasure to have you join us.
I’ve placed a spare parts enquiry on your behalf for the soft-start module for your Ryobi ECS23235 circular saw.
Our Spare Parts team will now check whether the part is still available and will reach out to you via email to assist further with pricing and availability.
Many thanks for your patience.
Hello, does anybody know where to get blades for this machine or alternatively can they be sharpened? I realise that the parts are no longer available - are there any 3rd party providers? my machine works fine it is just the blades are not cutting as clean as it used to be.
Would greatly appreciate advice on this matter. Picture of shredder.
Hi @MorrisonMinor,
Unfortunately, due to the age of the product, replacement blades are no longer available. So, you have two main options, either sharpen the blades, or replacing the machine altogether.
Generally speaking, Ryobi recommend any maintenance such as sharpening blades is carried out by a professional such as a small engine or lawn mower repairer. It might be worth getting in touch with your local mower repair shop to see if this is something they could assist with.
Outside of this, there are options for replacing the machine, such as the https://www.bunnings.com.au/ryobi-ac-2400w-crushing-shredder_p0082386 which you might like to consider.
Let me know if there is anything else I can do to assist.
I just thought I'd add, have you adjusted the blades to minimise the cutting clearance between them and the sacrificial plate? Over time, as the blades/plate wear down, the distance between them increase and the machine stops cutting efficiently. Typically, there is a blade adjustment knob to bring the blades closer to the plate. I'd give this a go if you haven't already.
