I need an inexpensive soundproofing solution for a sliding door that is not used for egress.
What would I use to affix one of these panels?
Welcome to the Bunnings Workshop community @MichelleLK. It's wonderful to have you join us, and many thanks for your question about attaching pinboard.You might find it a bit tricky to adhere the acoustic pinboard directly to the glass. For a permanent installation, you could use something like Selleys 310g Liquid Nails Mirror, Metal and Glass Adhesive, which is designed for bonding to smooth surfaces like glass. Just keep in mind that this option would be very difficult to remove later without potentially damaging the glass.
If you’re after something less permanent, you could try self-adhesive mounting strips, though in my experience, they may not bond well with the felt surface of the pinboard. A better option might be hook-and-loop (Velcro) tape—the hook side might grip onto the pinboard quite well. It would be worth checking the grip on a test piece in store first to be sure.Please let me know if you have any questions.Mitchell
