I'm told that double glazing of windows is a very good way to keep the heat in if you are in a cold climate where it can snow.
I stumbled across Suntuf 900 x 600 x 5mm Clear Acrylic Sheet in Bunnings recently and had an idea...
Would it be possible to adhere (on the internal side of a window), this material just using silicone? I understand that specially made glues will do the job, but I would like to remove the sheeting once the weather starts warming up. I could slice the silicone off to remove the acrylic sheet, but the special glues seem to be permanent, by design.
If it came to a pinch I wonder if bluetak could even be used as a temp measure?? Maybe even a clear double-sided tape??
Can these sheets be cut to size? What's the best way to cut them and keep a clean edge rather than a "furry" plastic edge which I imagine a handsaw would make?
I'm thinking just two windows in a particular room, not the whole house.
Pls feel free to point out problems. It won't be the last crazy idea I have 🙂 😀😀
Thx
