I’m trying to replace the expansion joints in the fiber cement boards on my alfresco ceiling/eaves. I purchased these PVC HardiePlank jointers from Bunnings (https://www.bunnings.com.au/james-hardie-300mm-smooth-pvc-hardieplank-jointer_p0712716), but I’m having trouble installing them as they’re not flexible enough to slide into the gaps between the boards.
Could you recommend either:
1. An alternative type of expansion joint that might be more flexible or easier to install
2. A specific technique for inserting these rigid PVC joints between already-installed boards
The current joints need replacement, but I can’t figure out how to get new ones in without damaging the existing boards. Any advice would be greatly appreciated.
