Hey Guys,
This is my first DIY project and i am trying to do my best with my limited skills 🙂
Presently getting my deck restored. The first few pics are before i sanded it off and the remaining are after sanding with drum roller hired with 80 grit paper and the edges and sides have been done with Ozite detail hand sander with 80 grit paper.
Few questions:
1. I have sanded with 80 Grit only. Do i need to sand with a 120 grit or more as well or i can go ahead with this ?
2. As you can see the ends of the deck which are exposed to weather are greyed. Do i use a Deck brightener/cleaner there or is there any other thing i can do ? Recommendations would help. I have sanded it already.
3. The Deck boards at the end are bit a uneven i.e. "up and down" probably due to it being weathered over time. May be the reason the sanding is not the best ? Will oiling also be an issue for the decks at the end ?
4. Do i wet clean it before oiling it or just oil it after blowing out the sand ?
5. I am using the Feast Watson Wet look Decking Oil as this was what was use by the previous owner. Is there a top coat required after oiling for protection from weather conditions or UV ?
6. I also have the previous owners Left over deck oil which is the same brand and type. Can i use that or its not advisable to use since its old ? Don't know how old it is though ?Â
Is there anything else i should consider and know ?
Thanks for all the help and hope to get answers to complete this over the next 2 days.
Before sanding
Before sanding
Before sanding
After sanding
After sanding
After sanding
Â
