Hello
Can anyone suggest what is the best way to clean indoor laminate flooring. thanks
Hi @Salam123,
I'd recommend you start by using Cabot's 1L Floor Clean. Once you've cleaned the floor as directed you can use Cabots 1L Laminate Floor Restore to rejuvenate and add a layer of protection to the flooring.
PREPARATION:
Ensure the surface has been cleaned with a duster or dust mop prior to using Cabot's Floor Clean to ensure loose particles of dirt are removed.
APPLICATION: Apply with a floor mop. 1. Add approximately 50mls of Cabot's Floor Clean concentrate to 4 litres of water. 2. Apply Cabot's Floor Clean to the floor with a mop to loosen grime and dirt. Do not flood the floor with cleaning solutions. Return excess solution to a bucket and allow the floor to dry.
NOTE: Floor may be slippery while wet. For Extra Dirty Floors Increase the amount of Cabot's Floor Clean concentrate to 100ml to 4L of water.
