I purchased these screws as I have steel studs, https://www.bunnings.com.au/zenith-6g-18-x-25mm-drill-point-gold-passivated-plasterboard-screw-100-pack_p2408870
However, I was reading that villaboard needs special screws because of corrosion. Anyone know if these serws are fine for villaboard?
Hi @anthonyu,
You should use Zenith 8G x 30mm Galvanised Countersunk Rib Head Metal Screws. The gal coating will prevent rust. They need to be driven 0.5mm below the surface of the board.
