Hi all, I'm hoping you might have some handy advice.
I'm renovating a small bathroom. Walls are concrete block to 400mm and I'm raising the floor 200mm with 100mm polystyrene with 100mm concrete. The floor will all be tiled with a walk in shower.
How do I lay the concrete to get the linear channel drain at the right height? The plumber has already done the waste drain, but the channel drain will need to sit slightly lower than the final concrete floor level.
Any tips or advice would be very welcome.
Thanks.
