I want to color this in Monument color.
Hi @saloni,
You can definitely refurbish your wooden chest and give it a sleek Monument colour finish.
Start by giving all surfaces a light sand with 240-grit sandpaper to smooth out any rough spots. Then, apply a coat of Dulux Max Adhesion primer to help the paint stick to the wood. Let the primer dry fully, then apply two coats of Monument topcoat paint, allowing each coat to dry in between.
This process will give your chest a fresh, durable finish that will last.
Hi @saloni you can as @MitchellMc has suggested below with using primer and then painting over or you can use a stripper on it also. It depends on how you want it to look if you like a painted look or wood look.
