This simple, low-cost timber bench seat was built using a Specrite Pine panel and angle plate legs.
The project
This is a D.I.Y. live edge bench seat.
Steps
Step 1
Measure and mark brackets including holes and a side marker to ensure the brackets are level.
The brackets should be positioned so the legs meet the edge of the seat about half way down. This will ensure the legs don’t sit out further than the seat itself based on the angle of the brackets.
Step 2
Once marked, drill the centre hole. Then smaller outer holes and screw the brackets down.
Mark the depth of the hole required on your drill piece with masking tape.
Step 3
Screw on the legs and check it stands.
All four legs should tight and angled from the centre outwards.
Step 4
Add sealer, lacquer or oil.
Always use a non-yellowing formula for sealers or a natural oil product to savour the tones of the wood. I have found Cabots clear CFP floor water-based maintains the colour of the Pine and protects surfaces really well.
Tools and materials
Tools used in the project:
[article footer]
More inspiration for D.I.Y. benches
Bunnings Workshop member Stuardo created a simple D.I.Y. shower bench using a timber bath mat.
Community member marliemakesit created a skinny bench using reclaimed timber.
Get more inspiration from 10 ways to build a bench seat and our Top 10 most popular outdoor bench projects.
[article footer]
