Hello,
I need to replace a rusting Roof Mounted Antenna on ColorBond Roof, I just need to must, Looks like i can reuse the bolts and just replace the Mast only.
Any ideas which part to use for Mast?
Thank you in advance.
Hello @JustinMcAbbe
I suspect that you might be able to rescue this antenna post. If it is still structurally sound and is only covered with rust, I suggest sanding it down and using White Knight 0.125L Rust Guard Rust Converter. Once it has completed its conversion, I recommend painting the surface with White Knight 310g White Gloss Rust Guard Epoxy Enamel Spray Paint for a long-lasting finish.
However, if you still wish to replace the post it will need to be replaced as a whole as the post and the support pieces are welded together. I suggest having a look at the Antsig 140cm Antenna Extendable Galvanised Fascia Mount as a possible replacement. Please note that this is a fascia mounted pole and not a roof mounted one.
