I am in the process of replacing a porch that had seen better days. I will be changing the orientation of the subframe so that decking runs outwards from the house rather than perpendicular.
I note in the past that @BIM_Engineer has been extremely helpful in confirming proposed plans from an engineering perspective.
The total porch dimensions is 15.5m x 2.7m - it will be installed as an independent structure rather than directly tied into the house - it will be tied into the existing roof support posts, but these will likely not be used to support the porch structure directly.
The proposed plan is a single bearer (140x45) notched into 90x90 posts - 3 supports per bearer - accepting that one is required every 1.4m - so really only need 2 but 3 seems more logical.
Then looking to run 90x45 joists - over bearers that will be spaced 1.4m apart - joists spaced with 450mm centres.
So there will be approximately 10-11 bearers over the 15.5m span.
Does this sound appropriate for this project?
I am in two minds about doubling up the bearers - but not sure it's required - presumably it would reduce the number of bearers required by expanding the span?
The general ground clearance / height off the ground is approx. 30cm - 60cm
It would be great to confirm if this is a sound approach.
Thank you
