How do i cut and prevent the grass growing in between footpath gaps if it has foam insert?
thanks
Hello @PJ88
If the grass has grown past the foam insert odds are parts of the foam insert might have deteriorated already. I Propose digging the grass and soil out of the gap along with some of the foam to create a channel that is around 15mm deep. Clean the gap as much as possible and remove any loose debris. I suggest inserting Moroday 15mm x 5m White Gap Filler Rod, it is available in a smaller diameter if you need it to be smaller. Push the filler rod in the gap and leaving at least a 10mm space above it. I then suggest using Sika 310ml Grey Concrete Sikaflex Pro+ Polyurethane Sealant to fill the gap.
The filler rod in combination with the Sika sealant should stop the grass from growing in between the foot path.
