hello. How can I remove this paint on the grout?
I am not sure but I will try the alcohol first. Thank you!
Hi @ShedSheeran,
Are you aware of what kind of paint was used?
Was it water-based? Or oil-based?
If it is water-based, you can spray it with some isopropyl alcohol, allow it to soak for a little bit, then wipe it off with a cloth or light abrasive pad such as these Scotch-Brite 155 x 100mm Non-Scratch Scourer Pads.
If it is oil-based, you can follow the same process with turpentine.
I'd suggest covering the skirting boards with a bit of painter's tape or cardboard to protect them from overspray.
If there is still some paint remaining, you can use a knife blade to gently scratch it off. Just make sure you wear gloves and long protective clothing to reduce the risk of lacerations.
